Alignment Offshore Eng Mounts
Every time I get pissed off working on strictly fresh water stuff, I remember the few salt water boats that I've had the "good fortune" to work on. Those pictures bring back some ugly memories.
For instance, we have one (super cheap) customer who bought a 28' Bayliner from North Carolina. He "saved a bundle" over buying one up here and this one was a real salt water beauty. It also included such wonderful options as a latex paint job (house paint of course) and all of the problems you might expect from salt. He's more than made up the savings in repairs on stuff that's broken, cracked, corroded or just plain vaporized from the salt water. You can have it!
I am the second shop that did the work to the boat and Robert is way off base coming on here and saying that the work was not being completed. He brought me the boat in the last week of April at the beginning of our boating season and the busiest time of year. There was a 1 month delay as Robert had used 5200 to install everything on the transom including the K-planes and gimbals.I had to order 7 3M decal removal blades at $54.00 each that took 3 weeks to get from 3 different sources which all got destroyed in the removal process.The removal of the transom hardware took 3 men 2 days to get off without totally destroying the transom at which time we almost gave up on doing the project. The original inner transom removal went as it should until we got to the repair done by the other shop. He used Epoxy resin by the ton and was a nightmare to remove. The stringers were also rotten including the forward firewall and stringers forward along the gas tank.
Now we are in the busiest time of the year for us and have twice the work we thought when the boat arrived but the Gach's wanted it now and I did everything I could to get it done. They MUST have it for the July 4 weekend and 2 weeks before I lock the doors and refuse to take on any other work until it was. I put my crew on 14 hour days myself working 16 to 18 hour days 7 days a week. Robert tells me that I should lower my work ethics and just put it back together the fastest way possible so he could boat on the forth.I went through about 10 times the grinding discs need to do the job because of trying to sand between layups before they were totally cured. Then during the week before the forth Roberts wife calls me while I am grinding in their boat and wants to know when it is going to be done. I tell her about 4 o'clock on saturday (July 2) and she goes ballistic on me saying that is not good enough for her she wants it Friday. I hang up after she starts getting nasty. I stop what I was doing and pull the boat out and bring in 3 other jobs that were not going to make the weekend but did.Instead of busting or balls on their boat 3 other families, my help and my family got to enjoy the weekend at which time I had only had 1 day off in 4 months (thanks Tina). Robert calls me back on Tuesday the 5th wanting to know when he can get his boat and I told him that I was going to work on it daily and doing it the proper way (not rushing everything) and we agreed that if I did not have it done and ready for water testing by the following Wednesday that I would wave all the addition costs of the repair which was thousands of dollars. We shook hands and he went home. He called me the next day telling me he changed his mind and decided that he wanted it now. Over the next 2 days we finished all glass work and he came and got it unrigged or painted. His decision not mine.Every time Robert came to the shop all without us knowing he was coming we were working on his boat.I could have had this boat completely done with 3 more days work and I would have felt a lot better about the beating I took but the customer is always right.
In regards to my wife (the customer) calling you upset, seems only reasonable to me considering the amount of “$” we were now loosing (and also paying you) for commitments we asked you multiple times if we should cancel. I don’t believe she went “ballistic” but, she (the customer) had every right to be upset. Especially, after you hung up on her. When I called you back on the 7/5 we did not discuss having the boat complete the following Wednesday. The last discussion we had was on 6/29 and you indicated the boat would be complete on 7/5 or 7/6 and this is also what you told my wife.
I was at your shop on 7/11 and that is when we discussed having the boat completed the following Wednesday (7/20, nine days later) for water testing. I did agree to that then and after further consideration felt that this date was not sufficient. This also would have required me to change other commitments and more lost time at work to this project and not having previously met any other prior completion time lines it seemed it was not worth the frustration. Therefore, I decided to pick the boat up on 7/15 instead of having more time wasted on unmet deadlines when there was nothing I could do about it even if the boat was not done by 7/20.
As you & I discussed previously my frustration was not that the boat was not done by 7/4, but, that you continued to indicate it would be complete and this was costing me lost deposit fee’s, vacation time for both my wife and I. All this could have been avoided. I brought my boat to you because; you indicated that you only work on off-shore boats and projects like mine. I guess my expectations as the customer are just too high.
Robert,
We never use 5200 for mounting large items on the transom. We use 4200 removable in those areas and told you that at the time it was going to be a problem. On the Monday after you dropped the off we did have the boat completely strip of its engines and all hardware except the K-Planes and that is when all the delays started. By the time the tools arrived to remove them the early spring rains had stop and our boating season was upon us.By then I had 17 boats sitting in my yard for work that were 1 and 2 day jobs that had to be done if I wanted any future business. I am sorry but those other boats were more important at the time than 1 huge project that should have been addressed during the off season. Had we been able to remove the tabs during the first 3 weeks this would have turned out much differently and been way ahead of schedule but it did not. You continued to make plans with the boat every week without it being done, that is not my fault but you kept blaming me while we WERE working on your boat every chance we could which most weeks over 80 man hours and some over 120.
Your wife had a nasty tone as soon as I picked up the phone and became VERY demanding. I tried to reason with her and she started to scream,.Thats when I hung the phone up and had enough ended my quest to get your boat done by the 4th.You were another issue with you downer attitude every time you came to the shop which considering our distance was way to much for my taste.When you would arrive I would just go about my work knowing your stay was only to bring gloom upon us and eventually you would go home.
I feel as most here would agree including all the customers that were after my time while I was doing your project that I did everything I could to get your boat done in a timely manor. Lets not forget that I finished it before anybody else you called would even consider taking it on.In your defense you did take it to the other shop in the fall but that has no bearing on the fact that I did not get it until 2 days before May. Poor planning on your part should not make me the bad guy and I feel your post yesterday was just an attempt to do that. I have been on this site for many years and your opening line of many members asking about your project by sending you PM's I feel was just a fabrication because I had already posted in the reply before your post that I had indeed taken on the project.
I am glad for you that you are boating and feel I am the main reason that you even made it in the water this year. Its just a shame that it was with bad feelings on your part and I had to go through all the hardship put on by you and your wife during the project that continues here still today.
By the way Rob please tell the members here how the project turned out quality wise. I would have made a complete pictorial of it on my site but I quit taking pictures after the project/customer became unbearable.
Or is that statement fabricated as a way of slamming brian41 knowing he would respond to defend himself, so you could reply?
I thought I read that when brian spoke with his wife that he would have finished the boat by 7/2 and that she got upset and told brian that wasn't good enough? 7/2 is still before 7/4 isn't it? Not sure at that point why brian stopped working on the boat and just didn't finish it up by 7/2 like he told the wife? It always sucks when things don't go as planned, thats boating though, get used to it. How long did gach own this fine piece of marine hardware?> Is he responcible for all the rot?
I was in Brians shop a few times the week of July 4 and seen gach's boat in there. Every time I was there he was working on it. Brians work is amazing, probably the best I have ever seen. And I used to do fiberglass work at Brennan Marine (now skipper buds) years ago before I joined the USCG. I can't stand impatiant people either, some people have no idea how time consuming glass work is and not to mention how big of a job gach's boat was.
Sorry, I didn't mean to offend or imply that Brian did anything but outstanding work. I understand how it al works, unforseen damage and delays. I am not one of those PITA customers, up your azz all the time. it sounds like this guy was. It makes it worse when your bustin your azz to try and accomodate the customer, no matter how big of a DIC hes being. I hope you got paid for all your time and effort?
I hope you got paid for all your time and effort?[/QUOTE]
When it was all said and done I made about 20% of my shop rate for the hours I put in it. Because of all the gloom they were giving me I just wanted it done and gone and did it for less than the original estimate because the thousand upon thousands of dollars they lost in trips they planned during the time I had the boat.
