gafrig
Old 05-02-2011 | 03:29 PM
mhydro4u@aol.com's Avatar
87cafe
Default gafrig
what would cause my gaffrig tach to run a little higher then normal, or bounce around?
mhydro4u@aol.com is offline
Old 05-02-2011 | 08:30 PM
Ted G's Avatar
Check for play in the distributor shaft. This will many times show up as tach bouncing and then break up over 3000 or so. Also any oil under the cap = bad.
www.cbpba.com
Ted G is offline
Old 05-02-2011 | 09:11 PM
check ground also
firehawkcat is offline
Old 05-03-2011 | 09:51 AM
87cafe
thanks guys!
Old 05-03-2011 | 12:35 PM
One of mine does the same thing at 4800+ rpms. I have checked everything and I can't figure out whats causing it.
Griff is offline
Old 05-03-2011 | 01:56 PM
cigboat1's Avatar
Time for New Auto Meter Pro-Comp Marine gauges !
Jim
cigboat1 is offline
Old 05-05-2011 | 08:47 AM
Before pulling your dist keep it simple and look at the back of gauge. The grey signal wire is either loose or corroded. That wire is the rpm signal. The purple is the power.
GTOFFSHORE is offline
Old 05-05-2011 | 11:13 AM
87cafe
thank you im gonna check out tonight!
