Iac Control
Old 06-08-2011 | 09:05 PM
Ted G's Avatar
If you removed the 4 bolts marked "36" in the pic, the throttle body will come off.
www.cbpba.com
Ted G is offline
Old 06-08-2011 | 09:38 PM
My set up uses "studs" that protrude through the "throttle body", the air cleaner slides over them and 4 nuts hold it in place, I cant see any way to remove the studs? Do the come out? I seem to remember trying before and not being able to move them
n20michael is offline
Old 06-08-2011 | 09:40 PM
I believe that drawing is of a MPI set up, mine is the older "EFI"
Old 06-08-2011 | 09:45 PM
Ted G's Avatar
Yeah, those studs are threaded on both ends. Use 2 nuts to lock against each other on the outer threads and back the stud out. (Or you can use vice grips but it may score it up some)
www.cbpba.com
Ted G is offline
Old 06-08-2011 | 09:55 PM
Ok, will give it a shot, Thanks!
Any thought on plugs?
Old 06-08-2011 | 10:01 PM
Ted G's Avatar
No, I always used MR43s in mine.
www.cbpba.com
Ted G is offline
Old 06-08-2011 | 10:20 PM
Ps: I am changing plugs too (gluton for punishment!) i was told the factory recommended ACMR43T are interchangeable with the NGK "R" YR5's, when I got looking at them, the NGK's appear to have a slightly shorter tip (looking from where the plug seats in the head to the electrode) is this important? The difference is maybe 1/16 th of an inch
Why not stick with the original plugs? If the plugs cross reference they should be the same heat range but what you describe surprises me. Definitely how much of the plug sits in the head will affect it but is that how NGK designed it? Again check cross reference.
Most info I see on the net is NGK BR6FS and AC MR43T are a match
Need4SpeedGTCS is offline
Old 06-08-2011 | 11:20 PM
I only have my iPhone with me, So, if SOMEONE with access to a PC could check for me, I would greatly appreciate it
Thanks!
Michael
Old 06-08-2011 | 11:44 PM
Use one of those. They are the correct plugs.
Griff is offline
Old 06-08-2011 | 11:49 PM
Ok, thanks, guess I will go out tommorow and rip out the YR5's I put in earlier! LOL!!
Better safe than sorry I guess!
Thanks guys!
Michael
