Why is a Chevy head still like this?
Every BBC Chevy head I mess with I always have to fill in these holes in the head for the manifold choke. These are off a Gen v motor. When was the last time Chevy used a manifold mounted choke to even need them?
Those holes are not for the "manifold choke" they are an exhaust crossover passage that is used to heat the underside of the maniold to help fuel atomization in very cold weather. It allows for decent driveability when the engine is cold. They probably have not been needed since GM stopped using carburetors but they are not going to change the head castings now. Also, most heads are used on cars and trucks, which still need the passage on older vehicles. By the way, filling them the way you are doing would not be my first choice. I would be real worried about the epoxy getting burned out by the exhaust gasses. Racers actually use melted aluminum to fill the passages, but for a street or marine engine all you need to do is cut a small piece of sheet metal to put over the passage and let the intake manifold gasket hold it in place.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
Yes, I have bought intake sets that come with a couple different metal inserts. You can not use them and leave it open, use one which has a small hole that only lets a small amount of exhaust through or use the solid insert that totally blocks it. I think most Fel-pro intake sets come with these....I could be wrong
