Gill manifold and riser torque specs? >
Old 01-31-2012 | 04:46 PM
Default Gill manifold and riser torque specs?
Anyone know the torque specs for Gills?
MCKILLOP is offline
Old 01-31-2012 | 08:20 PM
Default Fixx
manifolds dry 30-35 ft lbs. RiserdsWith a skim coat of sealer,25-30 ft lbs..
FIXX is offline
Old 01-31-2012 | 10:25 PM
Thanks. So a little sealer on the riser gaskets? I have 6 riser gaskets because of the spacer and a Turbulator. What should I use? I sure appreciate you help Fix. Thanks
MCKILLOP is offline
Old 02-02-2012 | 05:09 PM
Default fixx
you dont really need to seal them but i have a habbit of using quicksilvers perfect seal on them..keeps the corosion down on the alunimum parts..#92-34227-1
http://www.ebay.com.au/itm/MerCruise...item56486eb659
when installing,gasket,spacer,gasket,turburlator,gasket then riser..
FIXX is offline
Old 02-03-2012 | 10:08 AM
Thanks Fix.
MCKILLOP is offline
