Window Glass rubber strips. >
Old 03-24-2012 | 09:44 AM
You da man!
I have two new vent glass sections that came with the boat as those pieces are missing on the boat, but I need the trim to install them. Not really concerned with them being able to open, just want them in.
befu is offline
Old 03-24-2012 | 11:02 PM
Check your e mail & I will send you the dwg file..I want to compare vent windows and see if they are the same.
sprink58 is offline
Old 03-25-2012 | 08:52 AM
Will look into this monday since CAD and the boat are at work.
Brian
befu is offline
Old 03-27-2012 | 07:28 PM
They are not the same. want a pic to see the difference?
befu is offline
Old 03-27-2012 | 08:41 PM
sure...knowledge is power
sprink58 is offline
Old 06-30-2016 | 01:25 AM
The glass rubber seal often has two channels fit for glass inserts,I guess you may need similar pvc or rubber strip like this.If this item is not found in boat parts store,you may find it in automotive rubber parts store,they may have similar one fit for your glass.
sealrubberstrip is offline
Old 06-30-2016 | 03:36 PM
Scott was very busy today but spoke with Karen that was super sharp as well. As luck would have it...the 255 Lib shares glass and frames with the 242/272 and 302 up though '86. I suspected this and verified it today. Karen gave me the contact info for the guy in Tampa that bought all of the Water Bonnet frames and glass patterns when they shut down. When I talked to him this afternoon and gave him the pattern numbers that Karen gave me he perked up quickly. "You have the Flat Glass Sport Cruiser set up from '77~'86...I have all that stuff and can supply you with what ever you need"!!!
Oh hell yeah!! I said. I will call him back in the AM and get the specifics on the gaskets and other hardware I need.
So all you "Flat Glass" Formula guys out there take notice...Captain Sprink has hit the mother load on the glass and frames we need!!!
Stay tuned...
Maybe its a different guy, but I got the number of a guy in FL from formula and had no luck. I have no weathersripping at all in my front panes and am missing alot in my side windows. I would like to get every piece new if possible. Let me know how you make out.
79formula is offline
