Which sea water pump
Old 04-21-2012 | 08:16 AM
If u had it apart why would u just change the impeller??? If u look inside the houseing more than likely there will be a wear mark in the back. I change both and keep my old one for a spare cheap insurance,
boatrider82 is offline
Old 04-21-2012 | 09:31 AM
Look at the wear plate. If it has groves in it (most likely will) it needs to be replaced. There is also an O ring infront of the wear plate that needs replaced to keep it from leaking.
I have replaced the impeller only several time, even turning the plate around. As I get older my time is not worth not doing it right the first time.
1BIGJIM is offline
Old 04-28-2012 | 09:42 AM
I have always had to change the cheap plastic housing with the impeller. The housing seems to wear just as bad as the impeller, that's why I switched to stainless this year. By the third season, I'm saving money.
ThisIsLivin is offline
Old 04-28-2012 | 09:48 AM
You'll lose vacum if your plastic housing is grooved at all. Just replace it and save yourself possible issues if scored at all.
ZP'd is offline
Old 04-28-2012 | 09:54 AM
Mercruiser part # 46-807151A14...List price is $93.25. Includes one-piece pump housing and impeller. Aftermarket parts fail within 6 months.
speedmasters is offline
Old 04-29-2012 | 08:00 PM
thanks all I bought the Merc one with the housing. My old one was not bad so I kept it as a spare.
pluguglyinhere is offline
Old 05-08-2012 | 12:01 PM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
Mallory ones are just as good as Merc.
http://www.ebay.com/itm/Mercruiser-S...6e7571&vxp=mtr
Baja_342 is offline
Old 05-08-2012 | 10:55 PM
BUP
I sell and install all 3 just depends what the customer wants. Merc, Sierra & Mallory. Merc and Sierra are the same manu and by far the Mallory Marine housing is better and has better quality than the other 2. No comparison.
If anyone needs one of the kits let me know. It does not matter which one to me as I stock all three. I have nothing to gain nor lose to voice an opinion which kit is better. FYI
It is always wise to change as a complete kit instead of just impeller. Keep in mind the housing is plastic, they wear, they crack, they groove, they break. Mallory holds up better and is stronger. Their housing weighes double compared to the other 2.
BUP is offline
