smoked impeller on 525
Old 06-29-2012 | 08:21 AM
The boat finally went in yesturday, and it's running fine. I never could find all the parts, and I pulled everything apart, but the pressure on that side is the same as the other motor. I did the other motors impeller, although it was fine. Thanks for the help. I now know way more about the motors, and I also saw how I need to change the fuel pump oil every 25hrs with the motor oil.
fastmcars is offline
Old 07-15-2012 | 08:41 AM
How do you change the fuel pump oil?
verbi69 is offline
Old 07-16-2012 | 07:09 AM
I use a Turkey baster to suck out the old oil. I use Amsoil Severe Gear so I don't have too worry about fuel dilution.
ThisIsLivin is offline
Old 07-16-2012 | 07:42 AM
I find it easiest just to take the assembly off, only takes a few mins to get it off. This will let you inspect the sea pump and impleller, and makes changing the oil simple and effective. You can also remove the fuel pump from the hoising and replace the gasket, change oil, and inspect bearings.
4bus is offline
Old 07-16-2012 | 08:25 AM
Thanks for the info guys!!
verbi69 is offline
