Originally Posted by michaelb63
(Post 3741519)
base timming set at 19* so all in would be at about 29* should be right in the ballpark, but dosent seem like the timming is advanceing after 2500 rps like it should
ok could be a number of things,,did you try a colder plug?? did you tighten up the sparkplug gap? boost could be blowing out the spark..try a .028 gap and see what that does..
Originally Posted by Griff
(Post 3741869)
With the V6 module on a V8 engine, all the advance(10*) is in by about 2500rpms.
Make sure you're running at least 30* timing advance. Not running enough advance will cause high exhaust gas temps and burns valves.
| All times are GMT -5. The time now is 08:58 AM. |
