Power Tilt Resvoir
Old 10-18-2012 | 08:35 PM
Default Power Tilt Resvoir
I have a 1989 292 SR1 Formula. I have been told the someone makes a kit to adapt the newer 4 screw resvoir to the older pumps which only used 1 bottom screw through the use of an adapter plate. Anyone have a source for such a kit? Thanks
gt5-33 is offline
Old 10-18-2012 | 10:09 PM
Here's the bulletin on that.
http://www.mercruiserparts.com/bulle...2001/EN_04.PDF
Looks like you need kit 883169A1 if the pump is '89. Check if it has the 4 mounting ears. Probably won't. That kit is over $400 most places but here's one on ebay for quit a bit less.
http://www.ebay.com/itm/MERCRUISER-T...item46089ca736
One good thing about it is your getting a new valve body with it.
Just do a search on the part number and see what you come up with.
picklenjim is offline
Old 10-18-2012 | 10:59 PM
c_deezy's Avatar
Better off just buying a whole new pump that already has the four bolt valve body than the retrofit kit.
Updated link - http://www.ebay.com/itm/NEW-TILT-TRI...ht_2834wt_1186
c_deezy is offline
Old 10-19-2012 | 09:49 AM
http://www.ebay.com/itm/Mercruiser-M...2cd61c&vxp=mtr
Agree. However the one in the link is for a late model which uses the quick connect lines which I would be pretty sure you don't have.
Old 10-19-2012 | 09:13 PM
c_deezy's Avatar
Correct. I just grabbed the first one I saw and didn't look very close. Updated link above.
c_deezy is offline
Old 10-19-2012 | 09:46 PM
look on ebay,their is always one on their cheap..
FIXX is offline
