Where is the fuel leaking from? >
Old 11-25-2012 | 10:44 AM
Default Where is the fuel leaking from?
I've got a 96 VIP w/ 5.7 merc. w/ I think is a Weber 4barrel carb (it look like an Edelbrock). The problem is after it sits for just a few days, the fuel bowl on primary side will be empty. I assume that it leaks/drains out into the intake. But how? and where from? There is no signs of fuel leaking externally. There is no bowl gasket to let it leak out. Confused?!
Drinkin fountian is offline
Old 11-25-2012 | 11:51 AM
Its a common problem with Weber carbs as they get older. Not sure where the actual leak occurs.
Griff is offline
Old 11-27-2012 | 07:40 PM
i think it perculates and runs out throttle shaft. aluminum body heats up, steel shaft takes longer to expand thermally.
keith2500hd is offline
Old 11-28-2012 | 12:17 PM
Thats what I was thinking/afraid of, too! Not an easy fix.
