LCD TV mounting and wiring >
Old 01-13-2013 | 09:18 AM
I purchased a small tv at wallmart for 100 but i had to use a small inverter because it didnt have a ac to dc power adapter. Key was light weight because of the shock from waves.
I didnt have the nerve to drill mounting holes in the wall upholstery so i made a bracket that fit the same holes as that were in a cupboard door hinge and put it in front of the existing door. I used the smallest swivel bracket that radio shack had. It works great, cupboard still opens, and i can remove it without any holes in the walls.
snapcracklepop is offline
Old 01-13-2013 | 10:34 AM
professor_speed is offline
Old 01-13-2013 | 01:00 PM
Originally Posted by Payton
I see the Jenson 22"tv weighs only 10.5#. But if that is hanging from 4 mounting points or a swivel bracket, is that going to break and go bouncing around the cabin after a few times out in rough water?
Im considering replacing the factory built in 12 volt 9" tv VCR combo. I could mount a 15" flat screen DVD over the opening but are looking at what's the must rugged mounting set up. I might have to modify or make something at work if need be
johnny b good is offline
Old 01-25-2013 | 09:26 AM
Just my 2 cents... I have a 280 baja and I just bought a wall mount for my iPad. You can take it with you. Don't have to wire anything. And you can hook up a sling box to your house and stream tv with just an Internet connection. I'm in it under 500 and I use my iPad every day at home. Battery will last all day. Return the tv. I promise you will be more happy with this. The swivel wall mount cost 30 bucks on amazon. Most smart phones have a mobile hot spot app. Plus you can use it as a back up GPS.
chazfehn is offline
Old 01-25-2013 | 11:01 AM
In a larger boat, the TV can't be beat for viewing size. In my boat, I think the iPad would be good enough, and certainly a lot easier.
VtSteve is offline
Old 01-25-2013 | 06:46 PM
GO4BROKE's Avatar
I bought a Skyworth 12v dvd combo for the boat:
http://www.ebay.com/itm/Skyworth-19-...item4166382601
[img][/img]
GO4BROKE is offline
