Upgrade from Bennett Tabs to K Planes? >
Old 02-16-2013 | 11:47 PM
Yeah mine react fast. A lil bump of switch is sometimes more than enough. It's pumps just like merc drives. Very responsive.
Crude Intentions is offline
Old 02-17-2013 | 11:10 AM
Two pumps is a good idea, will have to keep that in mind if I see a spare pump. I have a spare trim pump, but not a spare tab pump.
befu is offline
Old 02-17-2013 | 11:15 AM
Mine look the exact same. Trim an tabs.
Old 02-17-2013 | 12:08 PM
I had the same debate and ended up finding a cheap Bennett 12 x 16 plane that I put on the existing system. The plane was much more beefy. If I remember correctly it cost me $160 for the planes (new but in someones garage off fleabay) and I had to drill some bigger holes (the pattern matched up but the screws where larger). They sell these with the dual cylinders but i ran mine with a single cylinder and it did fine. example http://item.mobileweb.ebay.com/viewi...id=79744055785
Port Monster is offline
Old 02-17-2013 | 03:31 PM
That's a viable solution. Thanks for sharing.
sprink58 is offline
Old 03-12-2013 | 11:15 PM
I have 150S K Planes on my 23' outboard vee. The smaller tab works great on my small 70 mph boat.
ar300johnson is offline
Old 04-01-2013 | 03:58 PM
i did the same about 2 years ago...found 16 plates to replace my 12.bolted up to the dual rams no problem.did need a 2nd row of screws to attach plate to boat. very happy with results..i think i spent around 150 or so as well.ebay
i think im going to give that 2 pump system a try my self
450RRRR is offline
Old 04-01-2013 | 08:37 PM
So you are saying your Mercruiser drive trim pump and your Bennett trim tab pump look the same?
motor is offline
Old 04-01-2013 | 08:44 PM
c_deezy's Avatar
If you can find some used ones in good shape I would go for it. Not sure I would spend $2K+ on them for a smaller boat.
I put used ones on mine, I've got about $700 in the tabs and pumps and worth every penny.
c_deezy is offline
Old 04-01-2013 | 09:17 PM
On that boat you can hurt yourself with k-planes if you aren't careful...Bennett's should be all you need. My Opinion, not that you care
motor is offline
