Dry exhaust improvising
Old 04-18-2013 | 08:27 AM
Default Dry exhaust improvising
Just wanted to share a little idea that I have used in the past but just got a photo of the new set up for my new boat. I am running stainless marine exhaust and I have a cam. I was a little worried about revision, so I made a solution. It cost me about 300 dollars, but it works great and makes the boat LOUD.
Stainless steel 3 inch flex pipe welded to the end of the riser with a stainless weld. Then I cut a 4 inch stainless steel flex pipe to use for the outside jacket. I connected this to the riser with a rubber boot. (stock one for the 454 with silent choice exhaust.)
chazfehn is offline
Old 04-18-2013 | 08:35 AM
I beleive you will have problems with that come time. If you take a look at my thread a few threads down, you will see what I did.
the problem you will have is the whole pipe will not cool evenly melting away your coupler. Also, I do not know how water tight that stainless tubing your running is.
Baldie is offline
Old 04-18-2013 | 09:26 AM
I appreciate your concern, but I have ran this set up before. Instead of using a 4 inch flex pipe on the outside, I ran the regular rubber boot. I had no issues what so ever. The rubber boot was actually not blistered at all after putting 60 hours on it. I am a little concerned about the flex pipe being water tight. I filled it up with water and let it sit over night and it did leak out but it was a slow drip. I am going to get some sort of wrap on the exterior so it will be a non issue. The only reason i am running a flex pipe is because of the difference in height in the picture below. Your set up looks really good, but I have had good luck with this in the past.
chazfehn is offline
Old 04-18-2013 | 01:49 PM
Awesome! I have about 550 in flanges, o2 bungs, and 1/2npt fittings!
Baldie is offline
Old 04-18-2013 | 01:58 PM
What cam are you using that your worried about reversion?
Baja226sport is offline
Old 04-18-2013 | 08:47 PM
Duration 284/296, Lift .574/.578
Peace of mind is priceless.
chazfehn is offline
Old 04-20-2013 | 12:27 AM
what is LSA (lobe seperation angle) of cam, that effects reversion.
keith2500hd is offline
Old 04-26-2013 | 07:13 AM
110 LSA, timing set @ 34. bored .40 over. Here's a pic of it in the engine bay. Doesn't leak a DROP of water after 15 minutes of run time!
chazfehn is offline
Old 04-30-2013 | 08:56 PM
Post a vid!
cjmatt is offline
Old 04-30-2013 | 09:28 PM
I converted a set to dry in my old boat when reversion became an issue. I welded the tails closed and welded bungs in for the dumps, worked great but wow was it loud! fyi 110 lobe sep. 231 duration @ .50 648 lift.
Attached Thumbnails Dry exhaust improvising-r0300017.jpg   Dry exhaust improvising-r0300018.jpg
RAPTOR1 is offline
