Sunsation Dominator 383 build project
#91
What is prompting the builds? Did you lose one or both? I'm holding off on props as I mentioned earlier. Bob put a 4 BBL carb he had laying around and made another 15 HP, so we know the throttle body is choking the engine some. BBlades thought I should wait until I do that, then probably jump up to a 25p and lab that. So far I've got a max of 72. One of the engines is giving me an alarm at WOT so I've not been doing any hard running besides long cruises until I scan it. Which she's done great on, I've kept the stock oil pan because it seems to be working great. Ran 3500-4k RPM from Clear Lake TX to Galveston, TX and my oil temps were perfect. If I wanted to lab what I have, they think there is a few MPH there. But, really...I'm just loving the acceleration and having a great running boat again so it's not high on my list right now. I forget who programmed it, I could dig it up when you're getting closer.
#92
#93
#94
If I were in your position I'd sell your stock engines and buy one of these bad ass big block setups I see for sale. You'd spend similar money. If not that, I'd sell them and do an LSx build.
I love my engines but I only did the build because I had to rebuild them either way and this build wasn't a ton more.
#95
#96
Where are you at? If you do dry headers you will hit 450 easily with my build. We held back a lot on the cam and if you do throttle bodies you might even do better.
I would really read over the Skater LSx build if I were you. That thing is nuts.
#97
Hey guys, I just dyno'd a small block for a 68 Camaro. It was a 427, dart block with dart 200 cc heads, 10:1 compression and a pretty big hydraulic roller cam, single 4 bbl carb.. It made over 600 HP at 6200 RPM. I was really impressed with the numbers. You could build a similar marine version that would easily make well over 500 HP in full trim.
#98
The attached build sheet is for a marine Dart SHP 406 w/ AFR 195 cc heads with a mild hydraulic roller. This went into a Magnum Starfire ~ 5 seasons ago. A very tractable, durable piece.
Bob
Bob
#99
Can you send me the link for that skater build? I never heard of a LS1 in marine application. At this point, I'm doing research and trying to educate myself. What I'm looking for is an 80mph boat on a light load. If you use the 11hp equals 1 mph gauge, I figure I can attain that goal with a 450hp setup. I'm a cruiser type of guy who likes to cruise at around 40-50mph, but every once in a while I like to open it up. Reliability is the most important factor in any build because there is really no point of doing anything if you are going to be broke down often or doing frequent tear downs. Plus, if I can get by with my bravo 1 setup, that's money in my pocket as well.
