Sunsation Dominator 383 build project
#71
Even with good bowl blend, you are at the limits of those heads. You guys made real good power for a fully dressed 383 vortec head engine and a marine cam.
If you want to step up the power and some more rpm, you know what you'd have to do next. Heads, complimenting cam, and thus forced into better exhaust because of more cam.
The power this combo made means you guys done good.
Have fun with it.
Have fun with it.
#72
Thanks SB.. I'm pleased with the results. I agree we're pretty much at the limits of this configuration.
It's really difficult to compare different builds when the dyno configuration varies so greatly. This same engine on a dyno with dry headers and no accessories would make over 450 HP.
Bob Lloyd
Bob Lloyd
#75
Don't know but I'll keep my eyes open. There was a guy in the shop the other day that had gotten a pretty complex windshield made out of plexiglass type material. It looked really nice. I believe he got it done in Houston, but was pretty pricey.
Bob
Bob
#77
Got this e-mail from Bob, thought you guys might like to know about it as well. He dynoed a pair of stock 6.2s, so this is a good indicator of baseline. We apparently made a very nice jump from stock numbers.
Just propshaft dyno'd a pair of stock 6.2s in a formula. They made peak power at 4700 rpm, and 285 HP at the prop. Adding a 10% correction for drive loss and they came out at 318 HP at the flywheel. That is with the same dyno and calibration we used on your engines, so it's a real apples to apples comparison of where we ended up with your engines.
