need some guidance on hatch lifts >
Old 02-02-2014 | 08:47 PM
Default need some guidance on hatch lifts
My engine hatch is also the rear bench, the brackets are still in place but no actuators.
Are these typically run with hydraulics shared from the trim or tab pump or are lifts typically electric? the boat is a wellcraft 260 eclipse[ATTACH=CONFIG]517784[/ATTACH]
thanks
Attached Thumbnails need some guidance on hatch lifts-bracebridge-20130907-01787.jpg   need some guidance on hatch lifts-img-20130907-01776.jpg
stimleck is offline
Old 02-02-2014 | 10:03 PM
Most hatch lifts are electric.
You can't run hyd rams off the same pump as something else.
Griff is offline
Old 02-03-2014 | 07:19 AM
Yep, Electric, hydro & air. Mine is Hydro in my Baja. Its a "kit" made by Bennett. It uses their pump, with 2-24" rams.
But every thing has it's ups and downs. The hyrdo is quiet, but it is sloooooow, and the reservoir on the pump isn't large enough to hold the oil needed to to fully extend the 24" rams.
Electric (ones I have seen) are "medium" speed. They are loud and the noise they make just isn't delightful at all. They draw more current also. On Steve's boat, if he opens the hatch, it makes the radio cut out due to the current draw.
92nsx is offline
Old 02-03-2014 | 03:40 PM
are you sure it doesnt use teh same pump as the tabs?
stimleck is offline
Old 02-03-2014 | 03:55 PM
You actually could by adding a T and solenoid valves. I've done it not with boats but its definitely do able. All valves closed, whatever switch you hit activates motor and that solenoid valve while the others remain closes.
Crude Intentions is offline
Old 02-03-2014 | 06:38 PM
Scarab2323's Avatar
thanks
Electric are cheap they work just fine you can pick one up for under 100 dollars had my 24" electric for 6 yrs with no problem
Scarab2323 is offline
Old 02-04-2014 | 07:45 PM
thanks any idea where? the ones I see online are 300+
stimleck is offline
Old 02-04-2014 | 08:22 PM
Rookie's Avatar
Your friend Steve might want to look into running his off of a couple of relays with 8-10AWG leads off of the battery. It will be twice as fast and no radio cutting out.
http://www.offshoreonly.com/forums/g...ft-switch.html
Rookie is offline
Old 02-05-2014 | 07:33 AM
Yes Im sure. I have 2 bannett pumps on my transom. (2 of the same model pumps). One for tabs, other for hatch lift. For the hatch pluming see post below. T fittings.
^^^^ Yep that sounds like how mine was plumed
This is the only photo I have right now of the pumps. In the corner of this pump you can see the pump for the lifting rams for the hatch. Plumed using "T" fittings. The other pump for the tabs is located right next to it. (out of the photo on the right)
92nsx is offline
Old 02-05-2014 | 03:56 PM
Scarab2323's Avatar
Try Great Lake skipper they got one for under 90 dollars it electric 27 in lift at 75 lbs
