how are you guys applying the rustoleum? spray, roll, brush?
Originally Posted by beaver 3
(Post 4107070)
I just roll and brush it. Levels out fine. |
Cool. I guess this is the route ill take on my pachanga then.
use the oil based gloss white, lowes/home depot about $10 qt, brush 2 coats on, be sure to let dry before second coat, just removed the carpet on side of my engine compartment and painting with it right now...
hey exstriper... I will be removing the carpet in my bilge this weekend before painting... what did you use to remove the adhesive from the fiberglass?
I used the rustoleum with hardener on my bilge and couldn't be happier. Do not mix all at once, a little at a time, unless you want a solid can of paint before you are done.
Don't forget to stop at a dollar store and pic up some cheap tin foil. Use the tin foil for masking of hoses and wires, goes on and off faster than tape! |
Originally Posted by f_inscreenname
(Post 4104265)
It's at Home Depot in gallon or qt cans. Use a can of Valspar hardener or it takes forever to dry. Mix in the hardner and you can dance on it in and hour.
https://encrypted-tbn3.gstatic.com/s...vGzXh&usqp=CAY |
Originally Posted by mysweetone
(Post 4107293)
would I use this hardner wtih an oil based paint?
And FYI in NY the only place to get hardener is a body shop supply store. Our hardware stores do not carry it. |
(Post 4107288)
http://www.harborfreight.com/power-t...ool-60428.html |
Thanks 4bus. I have a harbor frieght 15 minutes from me... guess I'm going shopping this afternoon!
| All times are GMT -5. The time now is 01:19 AM. |
