bilge coat or epoxy
Old 04-15-2014 | 08:30 PM
how are you guys applying the rustoleum? spray, roll, brush?
beaver 3 is offline
Old 04-15-2014 | 11:17 PM
If you are adding the hardener do not under any circumstance spray it unless you have a fresh air system.
I just roll and brush it. Levels out fine.
f_inscreenname is offline
Old 04-16-2014 | 08:44 AM
Cool. I guess this is the route ill take on my pachanga then.
beaver 3 is offline
Old 04-16-2014 | 08:51 AM
use the oil based gloss white, lowes/home depot about $10 qt, brush 2 coats on, be sure to let dry before second coat, just removed the carpet on side of my engine compartment and painting with it right now...
ezstriper is offline
Old 04-16-2014 | 08:53 AM
hey exstriper... I will be removing the carpet in my bilge this weekend before painting... what did you use to remove the adhesive from the fiberglass?
mysweetone is offline
Old 04-16-2014 | 08:55 AM
I used the rustoleum with hardener on my bilge and couldn't be happier. Do not mix all at once, a little at a time, unless you want a solid can of paint before you are done.
Don't forget to stop at a dollar store and pic up some cheap tin foil. Use the tin foil for masking of hoses and wires, goes on and off faster than tape!
4bus is offline
Old 04-16-2014 | 08:56 AM
Originally Posted by f_inscreenname
It's at Home Depot in gallon or qt cans. Use a can of Valspar hardener or it takes forever to dry. Mix in the hardner and you can dance on it in and hour.
would I use this hardner wtih an oil based paint?
Old 04-16-2014 | 09:09 AM
yes, works will all.
And FYI in NY the only place to get hardener is a body shop supply store. Our hardware stores do not carry it.
4bus is offline
Old 04-16-2014 | 09:11 AM
Go to the cheap tool store and get one of these, with some extra blades. It is like a putty knife, scraper, chisel, sander all combined and on crack.
http://www.harborfreight.com/power-t...ool-60428.html
4bus is offline
Old 04-16-2014 | 10:22 AM
Thanks 4bus. I have a harbor frieght 15 minutes from me... guess I'm going shopping this afternoon!
