-   -   Dyno Results: 502 w/ AFRs (https://www.offshoreonly.com/forums/do-yourself-boating-budget/312084-dyno-results-502-w-afrs.html)
Unlimited jd 05-18-2014 09:15 PM
A pro systems carb with billet base plate and wet flow sheet setup for your app is only $20 more.
Irishtornado 05-19-2014 03:11 AM
This is a great thread and have subscribed. I talked to Bob about doing this exact thing earlier this spring, but due to other issues wasn't in the budget so it's gotten pushed back to this fall. Great numbers with reliability. Thanks for sharing all this information.
ROTAX454 05-19-2014 12:31 PM
Good information. Note that my previous post was not intended for marketing value, but merely a product reference point.
tpabayflyer 05-19-2014 03:38 PM
Originally Posted by mike tkach (Post 4123818)
i am not against a firing order swap but i dont buy into the claims of big hp gains.in a 10,000 +rpm pro stock engine a little gain in hp can be big but once one team realizes the gain they all do it.the guys that think they will see a noticable gain in performance in the marine world might be dissapointed .this is my opinion but im not one to buy into snake oil,i like results,not hype.
I have a 18726543 cam as well and it has a bit of snarl to it and a decent idle for a 228/[email protected] with .600 lift. I did alot of reading and it looks like it reduces the stress on the crank and may add a little bit of power at higher rpm's.... Kaase has some data on his Ford engines and has made really good power with those type cams. Also, the new GM LS Engines also use the 18726543 firing order and they started with a clean slate for that engine design and they must have had a good reason for doing so??
