496 Transom Harness HELP
Old 05-25-2014 | 02:06 PM
Default 496 Transom Harness HELP
i have a merc 496 mag transom harness 865677a01 i have identified steering sensor,digital trim, analog trim,pitot,mercathode, and there is a long harness with 3 wires with bullet connectors which is unidentified purple green and blue can someone help me please
tazdevil is offline
Old 05-25-2014 | 05:44 PM
BUP
I take it you have a 496 with DTS
Blue is trim up to pump
Green is trim down to pump
purple is trim relay power
If I remember correctly but not 100 % about this for these 3 wires is do not plug these wires in all at the sametime with your battery hooked up / power on. Anytime working with wiring and plugs in unhook battery power / or battery turned off especially on computer controlled marine engines..
BUP is offline
Old 05-25-2014 | 07:00 PM
yes it 496 mag dts
tazdevil is offline
Old 05-25-2014 | 07:06 PM
BUP
I really already knew you had DTS by the way you were describing your transom wiring. Anyways your blue, green and purple wires are listed in the post above. Good luck
BUP is offline
