454 Bypass Help
Old 08-05-2014 | 09:15 PM
Default 454 Bypass Help
I have read many forums about Bypass issues. Here is a picture of my 454 Gen 5 block. Do all I have to do is change that outside bypass to a 30lbs valve?
If anyone could help me with what needs to be done that would be great
[ATTACH=CONFIG]527451[/ATTACH]
Satisfaction is offline
Old 08-05-2014 | 09:47 PM
Rookie's Avatar
Plug it. Send all oil through filter and cooler.
My $0.00002
Rookie is offline
Old 08-06-2014 | 06:50 AM
Thanks, Rookie, How are these removed? are they threaded or pressed in?
Old 08-06-2014 | 07:15 AM
pressed in ..stick a screwdrive in and pop it out pry on the edge
smokin' gun is offline
Old 08-06-2014 | 08:41 AM
Rookie's Avatar
You can get little freeze plugs. Punch the perimter corners to retain it in place.
[ATTACH=CONFIG]527462[/ATTACH]
Attached Thumbnails 454 Bypass Help-dscf0498.jpg   454 Bypass Help-dscf0498.jpg
Rookie is offline
Old 08-06-2014 | 09:25 AM
Problem solved. Thanks again Rookie & Smokin gun
Old 08-06-2014 | 07:55 PM
bigboat28's Avatar
I know it is a stupid question, but where exactly is that? I am getting ready to pull one of my motors (4th time) and wondering if mine needs this done. I have 454 Ho Chevy crate motors.
bigboat28 is offline
Old 08-06-2014 | 08:03 PM
that is oil filter mount boss.
dereknkathy is offline
Old 08-06-2014 | 08:09 PM
Rookie's Avatar
Where the oil filter or remote oil filter mounts to the block. You probably have the 11lb bypass in used in automotive applications. I plug mine so all of my oil goes to my filter. I look at it this way, if I have a plugged filter I have worse problems than a plugged filter.
Edit: If you have 11lb not only does it bypass the filter, but also the cooler.
You having bearing problems? Friend had a fresh ZZ502 that kept taking out bearings, this was the problem.
Rookie is offline
Old 08-07-2014 | 06:04 AM
takes about 50k miles to plug an automotive filter completely. 50,000 at 50 mph in a car is 1000 hours, and car spends lotsa time at 35, idling at stop lights, etc. there is NO WAY your boat filter can plug solid. (if it does you deserve to lose the engine!) so bypass better be unnecessary in boat.
