Interlux Perfection two part , use interlux epoxy primekot first than topcoat with the perfection..
Originally Posted by f_inscreenname
(Post 4189833)
Rustoleum but you must use the enamel hardener or it will stay tacky forever.
http://ecx.images-amazon.com/images/...L._SL1500_.jpg http://www.amazon.com/Valspar-4625-E.../dp/B000LNY1MY |
Is there a comprehensive thread on refinishing the bilge? Id like to know what how to sand and prep the area as well as other tips.
I clean with a good degreaser, dawn works well, let dry, scuff with a 3M scrath pad, blow of or wash again, wipe as much as you can get to with a rag soaked with reg alcohol, paint with a cheap brush with temps over 60 deg, let sit until dry and do second coat...done
+1 on the Rustoleum/Valspar. Looks great and very shiny...slipped and fell a few times while re-rigging the bilge, lol. My experience was slightly concerning with how thin the paint/hardner mixture was. I was covering bare glass and old gray gel (all sanded thoroughly) and at four coats I called it quits but I probably could've done six for better coverage. I did mine in an off-white color and it does show everything! If I were to do it again I would consider a dark color under the motors and white everywhere else to keep things bright (my wife says I need help 'cause I vacuum the bilge regularly). Again, still looks great and cleans very easy. Good luck.
What about screw holes from the rigging? Fill them with 5200 or?
"A clean and dry bilge is a happy bilge" I want a happy bilge and that is why I'm doing all this work. Thank you to everyone who replied. All good help.
Originally Posted by Cole2534
(Post 4191239)
I use a fiberglass style body filler on holes that will not be used, white sealer on the one that are after paint
Great, thanks.
| All times are GMT -5. The time now is 08:22 AM. |
