Drive Alignment Corsa
Old 09-18-2014 | 02:14 PM
Default Drive Alignment Corsa
I'm trying to dial in a 26ft Corsa. So far i have got to 80.1 mph at 5400rmp with a labbed 27 mirage 3 blade. The problem i'm having is when i trim the drive to far the rooster tail shoots off to the right side of boat. I would think if everything is square it would shoot straight back. Do you think or is there a way to make sure drive is square to transom. The boat has always torqued steered and i have to drag a tab on one side to level the boat. Thanks for any help.
PowerplayDave is offline
Old 09-18-2014 | 05:13 PM
I've seen many RH rotation props throw water to the right when trimmed way up. The blades near the top of the water are going that direction. Also, wouldn't the steering take care or any squareness issues by turning the wheel? A single with a fair amount of power and prop pitch will be affected by the rotational direction of the prop being that there is a larger volume of water below the prop than above it so the rotational force does not get cancelled out.
Quick2500 is offline
Old 09-18-2014 | 05:21 PM
That was kind of my thought, so +1
buck35 is offline
Old 09-18-2014 | 05:25 PM
Thanks what your saying makes sense.
Old 09-19-2014 | 01:32 AM
It won't ever be straight. Its due to prop rotation. With twins spinning out, the roosters go toward the outsides. Spinning in the roosters blend together into one.
Griff is offline
