Complete repowering of a brick
#101
Started the install of the engine, it takes a lot of chain pulling to pick it up high enough
Tried to install and it was not going in, need two shoe horns. Took it back out and repositioned the straps to put the engine at an angle tipping to the rear. This helped but still no go. So removed the seawater pump and alternator.
Managed to get it in and put everything back on including the new elbows. Most of this was done laying on top the motor hanging upside down. Don't know if I'm getting better or just getting use to the pain. Made a bracket to hold my lube bottle and go figure the hose is not long enough. This one is no issue, the hose is cheap and readily available
And now for the rest of the story, there seems to always be something else. My new exhaust elbows are 9 inches from the transom and about 1.5 inches high and to the right or the hole. Now I need about 12 to 13 inches of flexible exhaust hose. Seem no one has the Shields or Trident 252 of 252V (silicone) 4 inch hose. All backorder 2 to 3 weeks. Starting to think about a 4 inch pipe (copper or stainless) and 2 of my 4 inch boots.
Also had to remove the bar used to raise/lower my engine hatch because the elbows will interfere with it. now have to make something up to use the drive of maybe remove it. Don't think this will be a big thing but for now on the back burner
#102
Just called Marine Exhaust in FL asking them about their Flexible (wire reinforced) Silicone Hose. They sell it in 2 foot increments and is only $48 for two feet. Don't know how flexible it is so they are going to have someone call me to advise. Either that of found a 3 foot piece for $189 on ebay which is Shields Nautiflex Silicone Blue Series
#104
I was lucky enough to find an OSO member who was able to sell me some blue silicon hose at a decent price. I had similar misalignment, but with only a few inches from collector to transom to work with. Since you have a little more room, what about a short section of pipe and two of the silicon "hump" hoses? they are easy to find on the web, and most are rated for over 300*.
BTW, I thought I had it bad for having to dive into my bilge to work on my engine. remind me to never attempt to work on a cruiser! I can only imagine how much fun that would be with twins.
#105
I ordered the 2 foot section from Marine exhaust, figure 50 bucks it's worth a try. If it doesn't work out I'll go for the pipe and two hump hoses
#106
Doing the kind of work your doing in the bilge reminds me of when I changed the plugs on my big blocks in the Chris Cat. My girlfriend thought I had gone 3 rounds with a cougar and lost. My arms were so scratched up from reaching between the CMI headers and the inner lip of hatch surround (and the rub rail screw points on the inside) and my calves tore up by the engine mount brackets.
So yes you are getting used to pain.... Kind of makes you look forward to waterboarding.....
#108
#109
#110
They are eddie marine +3 runners. Don't know how I could get it done. The holes are off due to me eye-balling them years ago when I drilled the holes. Didn't have a template or even look what they should be. Drilled, installed silent choice and tips, worked great for years. Just replaced the 4-wire solenoids for 3-wire and added some pipe to the bottom two years ago. Everything still works today, could probably get CMI to make me something for next season if I run into to much of a band aid
