Complete repowering of a brick >
Old 11-19-2014 | 06:14 PM
  #81
Originally Posted by Budman II
AllDodge, are you going to dyno this engine before dropping it in the boat?
Yep, that is in the plan Eddie provided.
AllDodge is offline
Old 11-21-2014 | 04:45 PM
  #82
Does Eddie have a dyno, or does he use a shop near him for dyno service? What part of Kentucky are you near?
Budman II is offline
Old 11-21-2014 | 05:34 PM
  #83
Never asked the question about a dyno but didn't see one in his shop. Not to say there wasn't one there, the place was full of very nice boats he was working on and it was a good size building. I thing he had around 8 boats inside (Real nice Fountain Executioner).
I'm in south KY and about 2 hours from Eddie and he is near Nashville TN
AllDodge is offline
Old 11-22-2014 | 06:33 AM
  #84
Lol. That was probably TRL505's ex.
Cole2534 is offline
Old 11-25-2014 | 05:54 PM
  #85
Was on a thread here the other day on the issue of diverters and the OP had 525's. The end result was to install turn downs. After thinking about turn downs I think I'm going to go the same route. You have open exhaust when running and when you slow down they are as quite as non-diverter thru hull.
Got my new +3 up tubes today
AllDodge is offline
Old 12-21-2014 | 03:23 PM
  #86
Waiting for the stuff to come in to start the grinding so did a bit of work. Replaced the broken anodes on the new transom assembly, removed the exhaust boot and installed the exhaust block off plate.
AllDodge is offline
Old 04-08-2015 | 02:38 PM
  #87
Took a ride to see Eddie today to give him the new elbows. The engine looks real good and will be on the dyno next week. Eddie and Travis have done some real nice work. Opened up the fuel rail and will feed fuel from both ends and has a return line back to the tank. Cut down the intake and opened it up some.
In this pic you can see what the intake use to look like and that mine has been cut down so it is level with the inside of the plenum. Also charged from V-belt to serpentine
PS cooler mounted on the rear deck, cool fuel mounted were cooler was, port side low
Now I really need to get moving to finish the transom and other glass work
AllDodge is offline
Old 04-09-2015 | 11:45 AM
  #88
So Dodge what all has been done to the motor and what kind of power are you expecting?
Chris
Blueabyss is offline
Old 04-09-2015 | 12:20 PM
  #89
Everything inside has been replaced except valves and crank. Valve guides have been cut shortened, intake and exhaust have been honed along with combustion chamber, bored .030 over, and balanced. MEFI1 replaced with MEFI3, don't know what compression it will be running but Eddie tells me the engine will have over 100 extra HP. I don't see it going over 550 probably in the 525 range, but as before I want low end torque more then HP
AllDodge is offline
Old 04-11-2015 | 03:43 PM
  #90
Unless things change I'm going to go and pick up the engine probably Tuesday. Talking to Eddie he said the engine produced 545 HP and 617 Torque using 91 octane. He did two engines and believes the numbers are correct but will have paper work when I go to pick it up. Numbers will probably drop 15HP when hooked up to my exhaust. He uses dry tuned headers running through a muffler do to sound level.
When I'm done with repairs and ready, Eddie will come down and ride with to return for optimum performance
AllDodge is offline
