Originally Posted by AllDodge
(Post 4312777)
They are eddie marine +3 runners. Don't know how I could get it done. The holes are off due to me eye-balling them years ago when I drilled the holes. Didn't have a template or even look what they should be. Drilled, installed silent choice and tips, worked great for years. Just replaced the 4-wire solenoids for 3-wire and added some pipe to the bottom two years ago. Everything still works today, could probably get CMI to make me something for next season if I run into to much of a band aid
btw- I would pay my very good welder less than $150 for this.
Originally Posted by wannabe
(Post 4312738)
Doing the kind of work your doing in the bilge reminds me of when I changed the plugs on my big blocks in the Chris Cat. My girlfriend thought I had gone 3 rounds with a cougar and lost. My arms were so scratched up from reaching between the CMI headers and the inner lip of hatch surround (and the rub rail screw points on the inside) and my calves tore up by the engine mount brackets.
So yes you are getting used to pain.... Kind of makes you look forward to waterboarding.....:silenced: |
Coming into the home stretch
Gave it a quick between the bunk paint job today, plan to jack it up off the trailer at the end of the season and do it right for next season.
http://forums.iboats.com/filedata/fe...6069&type=full Installed the turns downs and readjusted the engine mounts for a better alignment. Having of time waiting for the hose I find myself tweaking things http://forums.iboats.com/filedata/fe...6255&type=full Uncrated the drive and was looking for the serial number, all I found was this tag http://forums.iboats.com/filedata/fe...6353&type=full Just above the Mercruiser label there is small print which sates "Serial Number" but there is none there. On the other side it has "Drive Ratio" which is also blank. Kinda figured that info would be there. Might give Gavin Marine a call to find out why it's not there http://forums.iboats.com/filedata/fe...6543&type=full Made me a tool to adjust the engine mounts easier. Not enough room to use a full length 1 1/16 wrench, but after you bend it a couple times t works pretty good. Like those cheap Pittsburg tools for such mods http://forums.iboats.com/filedata/fe...6675&type=full A few more war wounds for the tight quarters http://forums.iboats.com/filedata/fe...6801&type=full |
Contacted Gavin Marine and they bought an upper and a lower from Merc and put them together, this is why it doesn't have a serial number. I'm sure it's OK but bothers me to find out now the issue instead of knowing it from the get go.
Love to see the progress. looks good
I need to find out about this black cloud that is following me around. Checked the gear lube it was ok, then put the drive on and the props. A little later I see lube under the drive. Pull the props and it's the inner shaft seal leaking. Sure looks like they didn't pressure test it before putting the lube in. Everything about this project keeps going in the wrong direction. Now get to find out how to get warranty done.
http://forums.iboats.com/filedata/fe...4791&type=full |
I always tell myself when my projects are pooping the bed----"if it were easy, everyone would do it!"
Good one LOL
And the saga continues, Just received what Marine Exhaust said was their "flexible" 4 inch exhaust hose, this is as stiff as any hard way stiff hose, no flex to it at all. Then to add a bit more icing they only sent 1 foot. The website indicates that the minimum order is 2 feet and list a price of 50 each. So sounds to me like 50 for 2 feet and 100 for 4 feet and so on. Nope they did me a benefit by only selling me 1 foot. |
Do you have hose store near you called coliflower
| All times are GMT -5. The time now is 06:55 AM. |
