Zoom flywheel 168t as a mercruiser replacement? >
Old 12-01-2014 | 12:36 PM
Originally Posted by BUP
just asking to follow along, are you referring to marine OEM stock 350's as they are external balance or the scat cranks being balanced for the 350's ? .
It is 383 stroker build from a 1998 350 marine engine.
mike tkach is correct. The 1986 and newer 350's are externally balanced on the flywheel and with a neutral harmonic balancer.
As my old flywheel is junk, I want to buy the cheap 350 Zoom aftermarket one and let Scat balance the whole assembly.
I asked Scat already, but no reply so far.
silomon is offline
Old 12-03-2014 | 02:14 AM
BUP
I hear you. Its funny how Merc list the flywheel in the parts as its listed 1982 - 1986 showing 3 flywheels with 3 different part #s. They list the 12 3/4 and the 14 and another 14.
Anyways you are correct about the flywheel as I thought it was in 1984 for the persay external balance flywheel. As it looks like mid year 1985 was the change from GM for the flywheel.
BUP is offline
