-   -   SBC to LS(style motor) (https://www.offshoreonly.com/forums/do-yourself-boating-budget/321738-sbc-ls-style-motor.html)
turbom700 01-05-2015 01:50 PM
A little back story, built this “boat” (http://www.offshoreonly.com/forums/r...oon-build.html) a few yrs ago and thought I would be happy with the 4cyl (140hp) coming from a tune with 25hp. Well I I’m happy but I would like to have a cruise speed of 30mph not a WOT speed of 30mph.
I started looking around a bought a complete boat that was rotten out with a running 350 sbc in, but after doing some more thinking I like to be different I thought why not do a LS instead of a SBC. I picked up a 5.3 out of truck with less then 80k on it. Everything from flywheel to accy including wiring a computer.
I’m sticking with EFI as that will be really nice when just cruising along at Idle have a few adult drinks.:cool-smiley-027:
It seems LS marine manifolds are hard to come by and are not cheap, Looks like I will be making my own water cooled heaters along with risers.
Computer still a little unsure off but should be able to get 02 Sensors in the headers someplace.
What else I’m I missing?
Anything I should be aware of with these motors?
professor_speed 01-05-2015 02:53 PM
The crusader manifolds are not too bad and they are made similar to an ls7 manifold. unless you are trying to eek out the last 10-15hp don't bother with making your own headers. But if that were the case you probably would have started with a 6.0l, maybe make you own risers like the guy with 5.3l's in 24 skater.
turbom700 01-05-2015 03:01 PM
Where can one find the crusader manifolds did some searching and didnt come up with much besides they are out there. My other reason for making them is cost, I can fab up s.s headers for alot cheaper then I can buy cast one for.
ezstriper 01-05-2015 03:13 PM
try to find manifolds, and yes you will need ones you can get a 02 in search the LS on here more info already on here...
phragle 01-05-2015 03:37 PM
http://www.skidim.com/prodinfo.asp?number=R028023
http://www.skidim.com/prodinfo.asp?number=R029016
http://imcomarine.com/cal_store/exha...-polished.html
http://www.marinepartssource.com/new...&mfgno=R028023
http://www.cpperformance.com/p-14931...manifolds.aspx
http://www.keperf.com/p-15856-gm-ls-...st-system.aspx
TooLateVTEC 01-05-2015 04:39 PM
If you dont want to worry about the o2 sensors you can have the ECM given a custom open loop tune so its not looking for a signal from o2 sensors, a MAF, etc.
turbom700 01-05-2015 05:03 PM
Thats exactly what I was planning on doing, not the "best" for HP but I'm pushing 3 giant logs thru the water.
Any one want to guess what kind of MPH I will see out of this boat with 300hp?
Right now with a worn out mid 70's 3.0l(140hp) with a 4 blade 16 pitch prop I see 28mph with me and the wife in it.
TooLateVTEC 01-06-2015 10:46 AM
Yep, for what you are doing with it that's exactly what I would want. to do.
dereknkathy 01-06-2015 05:24 PM
here is how to get a pontoon up on plane. wonder how much faster it would be without the living room furniture. https://www.youtube.com/watch?v=DLRwkrBZzsA
FIXX 01-06-2015 05:38 PM
im gonna guess 60 mph.. here is one to vopy off of.. http://www.youtube.com/watch?v=8RhwmnWq6ZY
