Where to buy 2006 496 HO water pump rebuild kit???
You are right about that kit BUP. I hadn't noticed it didn't have a spacer for the rear plate to make up for adding the front plate. I bought kits some years back from a machine shop in Texas(forgot the name) that were 3 pieces. Put them in and forgot about them. Just changed the impellors this spring after 5 or 6 years, lol. Still in good shape.
[img][/img]
[img][/img]
If you still drop in the small round front wear plate it is taking up space inside the impeller housing so how can the exact same sized impeller work that is used when the round drop in wear plate is not used ??? Standard impeller for standard OEM impeller housing.
Impellers and impeller housing are all About proper tolerances to prime and flow the correct amount volumes of water.
It would be like using .30 over pistons in a stock cylinder bores something not going to work correctly.
Lets just say the .30 over pistons are made out of rubber going into standard metal bores- .Sure I can squeeze the hell out of the rubber pistons to go into the metal bores but that does nt mean the tolerances are correct like they were engineered and designed for..
The back side heart shape wear plate is not the problem - it does not take up any space within the impeller housing.
I have used them several times and they ran forever. Only thing you need to do is make one of the mounting holes oblong to make up for the difference of the shim in the cover.
Yeah, what vindicator said. One stainless plate under the impeller, then one shim and 2 gaskets for the cover.
So the gasket is the same thickness as the drop in round wear plate ? Also how well does that seal as you have an O ring gasket that is the seal but now you are adding a gasket on top of the oring seal, That really is not the greatest way to seal the 2 sections of the housing together.
Also the further you space the aft section of the impeller housing back - the one mounting bolt on the side of the housing will be off centered ? they must want you to ream the hole out a tad bit to be able to get the that bolt centered to screw in correctly.
Basically, without putting a mic on it, I would say yes the gasket is roughly the same thickness as the wear plate. It seals well enough not to leak. Now how long it lasts without leaking I wouldn't know, maybe Keith can answer that one since he's had more long term experience. Not sure what I'm going to do the next time I change the impeller though. I may have to make my own gaskets. Can't imagine having to buy a whole kit just for the gaskets.
Thanks for your time and replies. As you and anyone including myself it goes totally against for anything to seal properly on a engine to double up gaskets especially when 2 gaskets are totally different.
One is an o ring gasket and the other is a flat all the way across gasket. There is no part on any engine that I know of were you put 2 totally different gaskets of materials, size, shapes and compounds completely together to seal properly from the OEM's.
I went to JC marine website they must have changed some things from the past. I do not remember that they had an inner gasket and that other plate that does not come in the Kit.
http://www.jcmarinellc.com/water_pump_kit.htm
