Best carb for this bbc engine
What would be the best carburetor and jet set up for a 509ci about 550hp with 9.1 afr heads with 741 cam. Cmi headers..
Looking at buying a brand new holley. Also looking at the ultra xp carbs, since I have a dominator intake on the motor. And would rather not have to change the intake . What cfm would be the best? 850?
since you already have a dominator intake i would go with a 1050 2 circuit carb.i like the quickfuel carbs but plenty of brands to choose from.some are going to say that 1050 is to big but my experiance sais otherwise.
Not perfect but would work well. Probably easiest to tune since it was 'factory' tuned to a little lesser of a motor.
An 850-950 (or HP1000) would be right on the money. If engine is machined, assembled and clearanced right, the OP should have between 575-600HP.
Don't see the need for a million dollar carb on this one, but that's my opinion.
Well, you have a dual plane, so you are effectively using less cfm out of your carb than a single plane intake would, so yeh, you could use a bigger carb.
Great low cost flowbench for a carburetor is a vacuum guage.
