What causes a lifter tie bar to break >
Old 10-05-2015 | 06:02 AM
Sonic30ss's Avatar
So I did some research, looks like valve spring is a comp 954
210 seat/530 open, it's the spring that comes with the assembled 308 iron eagle.
Sonic30ss is offline
Old 10-05-2015 | 06:38 AM
Well valve float sure wasn't the cause
Unlimited jd is offline
Old 10-05-2015 | 06:45 AM
Sonic30ss's Avatar
Lol ya think?
Maybe too much spring?!??
Going to try to get down tonight and pull timing cover off to get a look at cam #s
Old 10-05-2015 | 07:47 AM
what lift cam ? possibly coil bind without enough installed height ?, need to match the springs, retainers to what the cam needs..
ezstriper is offline
Old 10-05-2015 | 07:55 AM
Sonic30ss's Avatar
[QUOTE=ezstriper;4362423]what lift cam ? possibly coil bind without enough installed height ?, need to match the springs, retainers to what the cam needs..[/QUOTE
Need to get the timing cover off to check cam #s hope to have time today
I did not build theses motors
Old 10-05-2015 | 07:58 AM
Dart iron eagles came with either the 954 comp, 936 comp, or the vasco H-11 springs.
936 145lbs seat max lift .660
954 195lbs seat max lift .690
Vasco 250lbs seat max lift .790
Over springing a hydraulic lifter that is incapable of sustaining higher spring pressures, can also have negative effects on valvetrain control, just like under springing. Like if trying to run 500 plus lbs of pressure on a autozone flat tappet with 5w20 oil lol
MILD THUNDER is offline
Old 10-05-2015 | 07:59 AM
TomFTM's Avatar
On any performance motor , I would never put on an assembled cylinder head from a head manufacture without disassembling and checking everything.. Spring pressures are usually off , installed height is off and valve job is wrong for the application.. U have to realize they don't have engine builders or machinists assembling them ..
TomFTM is offline
Old 10-05-2015 | 07:35 PM
Sonic30ss's Avatar
Dart lists it at 190 @ 1.900
Comp lists it at 210 @ 1.900
who to believe?
Old 10-05-2015 | 07:36 PM
Sonic30ss's Avatar
Understood and have done on my own builds in the past, they may have checked them out I don't know.
SB
who to believe?
Comp, but, really...You, when you measure it yourself.
SB is offline
