Installing roller rockers and supercharger...
I think the zz502 will work with the net lash stock rockers with orig length pushrods. Same base circle and not a huge amount of lift. My gen6 came with roller rockers and stock cast alum gen 5-6 valve covers. Oil splash tabs ground off inside of covers and 2 gaskets stacked. What u running for exhaust. That duration with 110 lobe sep will cause reversion with stock mag exhaust and be borderline with the 8.1 gils...
I am running the stock cast aluminum Gen V/VI valve covers with the Scorpion Marine Endurance full rollers, but I had to double up the gaskets and use extra thick ones.
The exhaust is CMI dry to the tip.
I just received a replacement set of Crane Gold roller rockers, they are not the old style flat top, these have an arc on top and the back is angled cut. Still the same p/n as the old style. The rockers hit the standard poly locks that come with the lifters at zero lash. Changing push rod length does not help. Cam is # 741. Crane does not show this sit on the web site.
