525SC intake options
Old 04-28-2016 | 02:47 PM
Default 525SC intake options
It seems like the topic has been discussed a few times but not many have divulged their solution. I've got one good intake and one bad (way past being welded) intake. Cant find another good intake so it seems the 6130WIN intakes are the only option... The problem with those intakes is the thermostat housing is under the blower snout. I've heard there is an adapter to get the thermostat housing over to the left side but have yet to see one. Any input on this conundrum?
Thanks!
VortechSS is offline
Old 04-28-2016 | 03:58 PM
http://www.jegs.com/i/Weiand/925/6220/10002/-1 there ya go....
phragle is offline
Old 04-28-2016 | 05:35 PM
That was easy! It looks like there will still need to be a spacer between that and the thermostat housing to get the header hoses up and over the snout on the blower though... essentially the difference in height between that adapter and the t-stat pad of the original intake. OR does that adapter make up that difference... It's hard to tell in the photos.
Thanks!
Old 04-28-2016 | 05:44 PM
or polished for a few bucks more
http://www.summitracing.com/parts/WND-6221WIN/
MILD THUNDER is offline
Old 04-28-2016 | 05:50 PM
http://www.summitracing.com/parts/WND-6131WIN/
http://www.summitracing.com/parts/WND-6130WIN/
Same deal, not much more for the polished version
Old 04-29-2016 | 05:44 AM
I had a marine 177 setup a few years back, came with that, but I never used it, used a crossover and a billet housing and cleared fine
ezstriper is offline
Old 04-29-2016 | 08:54 AM
Thanks!
I have 1 of these
smokin' gun is offline
Old 04-29-2016 | 12:54 PM
Do you have any pictures of the T-stat housing you used?
Originally Posted by smokin' gun
I have 1 of these
PM what you want for it.
I'm going to go ahead and get a set of the 6130s. No need for polished as I prefer the stock look.
This also means I'll have a stock Merc 525SC intake for sale.
Old 04-30-2016 | 08:25 AM
here you go, hard to see, second pic is same housing on a different engine and a thermostat w/bypass installed, did not run that way with the 177
Old 04-30-2016 | 08:28 AM
