Carb tuning
Old 06-08-2016 | 10:47 PM
When adjusting air bleeds motor is changing trying to keep idle low
28ftsportcat is offline
Old 06-08-2016 | 10:50 PM
Also elevation is at 4000
Old 06-08-2016 | 10:51 PM
The surging you are seeing should be able to be tuned out with the mixture screws and the proper idle speed screw setting
MILD THUNDER is offline
Old 06-08-2016 | 10:56 PM
Thank u for your help
Old 06-08-2016 | 10:59 PM
Good luck. Once you get it dialed in you should have a good combo.
Old 06-10-2016 | 08:36 PM
Can you be clear on what model 750 carbs your using? Are they the Holley hp 750 supercharger carb as was stated in mild thunders post or are they 4779-? This can change things up a bit.
Btw the surging at idle is common even on Mercury hi perf supercharged engines. You can calm it down some with tuning as MT stated but not uncommon to have a little lope even with that cam or any cam as far as that goes.
getrdunn is offline
