Crane Cam
Old 04-07-2018 | 06:34 PM
Default Crane Cam
Does anyone know what grind this Crane cam is #'s engraved around the edge are "139641" Also engraved is "13-14-97 CR"
These are out my 540 engines any info would be appreciated Thanks
ahlenius is offline
Old 04-07-2018 | 07:14 PM
If it isnt in their latest catalog which is available on the web site, then give them a call. They are very helpful at looking at older part numbers and can e-mail you a cam card.
BillK is offline
Old 04-07-2018 | 08:38 PM
I believe this is what your looking for
234/242 at .050, .610/.632 ls112
sutphen 30 is offline
Old 04-08-2018 | 09:04 PM
Ok so is This an acceptable for a marine 540 with a SC3300 Whipple and Carrillo rods and Kryptonite crank I'm not a Gear head so please I welcome any advise or comments,Thanks
ahlenius is offline
Old 04-09-2018 | 12:59 AM
Acceptable.......Yes. Its very close in specs to the Crane 168741. https://www.summitracing.com/parts/crn-168741.
Optimal,..... maybe. It looks like its for your Aronow Cat which is very heavy. It may not make the most HP, but the torque should be good.
Griff is offline
Old 04-09-2018 | 09:47 AM
Yup came out of the cat! I was pondering having Marine kinetics grind two new ones, That old beast will never ever be a speed demon, so maybe i will use them. Im looking more for reliability and longevity rather than hp.
ahlenius is offline
Old 04-09-2018 | 10:01 AM
You may want to research Marine Kinetics before you do that, or have all of the threads been deleted?
snapmorgan is offline
