Is it OK to support the motor by the oil pan? >
Old 05-22-2018 | 02:05 AM
Default Is it OK to support the motor by the oil pan?
My question is it OK to just stack 2x4's under the oil pan to hold the motor in place while I work on the motor mount or will it bend/break the pan?
If the answer is no what are your, suggestions on how (where) to support the motor while I sneak the new mount in? (I have a 502 EFI).
The boat uses a mount like shown below and I want to add a 4" x 7" 1/2" thick plate I had made under it to raise the mount. Currently the lower nut on the mount has to be raised all the way to top to align the motor correctly (raised so far that the top nut does not engage all the threads). The drive is off for rebuild and I want to address it now before it is installed (and aligned).
No, the wood that the part below is not rotted the mount has not moved, this is how the boat came from the factory....
Thanks in advance,
Mike
boating4me is offline
Old 05-22-2018 | 04:45 AM
Default Oil pan support
I think you can support it by the pan. I transport mine in the back of my truck by sitting on the pan. Although the weight is even distributed across the entire bottom, I guess you should pay attention to how and where you place the wood but it shouldn’t be a problem.
ezrizer is offline
Old 06-03-2018 | 07:39 PM
No
Romeomikehotel is offline
Old 06-03-2018 | 09:55 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Could you place a doubled up 2x6 across the hull and support that side of the motor you are working on with a strap?
US1 Fountain is offline
Old 06-04-2018 | 07:43 AM
The correct answer is no. Should be supported by bell housing and mounts
1MOSES1 is offline
Old 06-04-2018 | 08:33 AM
the correct answer is yes.it is totally safe to support the engine by the pan while you are repairing the problem.i have done it many times.
mike tkach is offline
Old 06-04-2018 | 08:44 AM
Ginger or Mary Ann?
Quit screwing around and do it my way Lift that puppy up and get’r done
Old 06-04-2018 | 09:37 AM
Wobble's Avatar
SORE MEMBER
The correct answer is mostly yes but sometimes no.
Wobble is offline
Old 06-04-2018 | 08:38 PM
because you did it a few times and nothing happened doesn’t mean it’s a good idea.
1MOSES1 is offline
Old 06-05-2018 | 12:48 AM
so tell me the facts of why your answer is no.i am always wanting to learn and factuial information is a good teacher.
