Back fire on start stock 496HO
#44
Thought it was going to this person ? As he should have it fixed by now and found the problems at hand ? just saying and just asking
#46
also guys i have to agree with bup, if youre using auto zone parts instead of mer cruiser you're just asking for trouble,just recently i tried and iac made by sierra which a marine application and it sucked,idle was too high,so high the cam wouldn't even chop and idle speed was higher so i went back to quicksilver and idle is back to how it should be,using aftermarket autoparts might give you a new set of issues if you ask me
#47
Finally got back into the engine room after weeks. Went to start; no ignition. Classic CPS.......had before. This is the third one in 7 years and only 200 hrs. Swapped it out and BINGO; running like a raped ape again. Nothing negative, mirror image with port engine. I think I have a serious Electrolysis problem. Will need some advice on that, both engines do not appear to be grounded to one another. Any way I’d say I had a slowly failing CPS that finally totally failed.
#48
take it for what ever its worth,I would run a ground wire from one engine to the other,
#50
Grounds and resistance and EMI and RFI can be the reason for running issues and the cause of sensor failures over time. The water pressure sensor fails easily from EMI / RFI. The crank sensor as well but not like the water pressure sensor. .
