LH RH Rotation Twin Engine V drive >
Old 08-19-2018 | 03:46 PM
Default LH RH Rotation Twin Engine V drive
Had a customer buy a boat from auction. It is twin engine vee drive, Mercruiser 350's. Port engine is there, standard LH rotation. Starboard engine is gone, trans/vee drive still there, but nothing else on starboard side for the engine. Boat is late 90's early 2000's. H.I.N. is covered by swim platform. My question, since I need to replace the starboard engine, will it be LH or RH rotation. I'm thinking standard/LH rotation, reverse rotation done through trans/vee drive, but not sure. Both trans/vee drives have exact same numbers, no indication of LH or RH rotation. Any thoughts ? Just found hull number, 2000 model Sea Ray Sundancer 310.
sdba069 is offline
Old 08-19-2018 | 09:54 PM
It will be a RH motor. Merc trans (more then likely a B/W trans) can spin both ways (by flipping the pump over 180 degrees) but it has a forward and reverse gear and can not be run in reverse for long. No matter what though a B/W trans can not change the direction of the rotation by it's self.
f_inscreenname is offline
Old 08-20-2018 | 06:36 AM
Mbam's Avatar
Offshoreonly Advertiser
That is correct unless it is a 5000 series or a Hurth/ZF. I don't remember when the switch was made.
What is the model number on the transmissions? Or the existing engine serial number?
Mbam is offline
Old 10-02-2018 | 05:38 PM
No numbers on the existing engine. Tranny/vee drives are Velvet Drive 5000 series which are reversible. Both trannies have the exact same numbers 20-02-003. So.. I'm guessing both engines will be LH rotation with starboard tranny reversed. What do y'all think ? Port prop is LH, stbd prop is RH.
sdba069 is offline
Old 10-03-2018 | 07:15 AM
I have a friend with a late 90's 300 sea ray 350's V-Drive and the port engine is a RH reverse rotation engine, is the starter still on bell housing ? if so power it up and see which way it spins
ezstriper is offline
Old 10-03-2018 | 10:25 AM
Port engine is definitely LH, standard rotation. I had already pulled the starter and was able to get it to turn enough to tell engine rotation, assuming starter was correct.
sdba069 is offline
Old 10-03-2018 | 10:36 AM
Mbam's Avatar
5000 Series ONLY works with standard LH engine rotation. With these transmissions the prop rotation is changed in the the trans.
71/72 series requires opposite rotation engine.
Mbam is offline
Old 10-03-2018 | 10:48 AM
Yes sir. I made note of that a couple of posts up. Thanks.
sdba069 is offline
