Molded bypass hose from recirc pump. Source? >
Old 09-10-2018 | 11:52 AM
Default Molded bypass hose from recirc pump. Source?
This seems like it would be a common problem but a search didn’t pop up any immediate info.
My new airgap intake is much taller taller than the stock unit so that little hose is too short. Anyone know where to get 3/4” hose with a 90* bend?
Baja Rooster is offline
Old 09-10-2018 | 11:55 AM
Nevermind. Amazon to the rescue.
Old 09-10-2018 | 11:56 AM
F-2 Speedy's Avatar
your local auto parts will have the same thing, cut to fit
F-2 Speedy is offline
Old 09-10-2018 | 12:02 PM
The one I got at O'rileys was long enough, in fact it needed trimming. The real problem I had was the hoses from the thermostat housing to 1) recirculating pump 2) to oil cooler. I ended up getting double barbed straight S/S fittings for both and trimming 2 hoses for each to avoid kinking at bends.
Good luck.
GLENAMY 242SS is offline
Old 09-10-2018 | 02:52 PM
SB
I don't use one. Most t-stat housings do the same thing. IE: have a bypass within them
So....what do you have for a t-stat housing ?
SB is offline
Old 09-10-2018 | 03:16 PM
Have you been to my local auto parts store?
Old 09-10-2018 | 03:18 PM
stock Merc MPI thingy. Four ports; big recirc pump, header hoses, freshwater intake.
Old 09-10-2018 | 04:35 PM
F-2 Speedy's Avatar
My local Vato zone just points me in the general direction and lets me go find it.....lol
Old 09-10-2018 | 05:33 PM
SB
If it's the tpical housing in diagram below:
That housing recirculates water back down to the inlet of the recirc pump (amogst other thigs) so that bypass hose is not needed.
If the pipe is threaded in the recirc pump, unthread it and put in a brass pipe plug.
SB is offline
Old 09-10-2018 | 05:52 PM
Thats the critter! I noticed two ports in the housing feeding the thermostat so that makes sense. I just have to remember to install the thermostat the right side up . Thanks.
