Longer hose from recirc pump to thermostat needed. >
Old 10-03-2018 | 05:13 PM
Default Longer hose from recirc pump to thermostat needed.
I put on the taller airgap manifold on the 509 and the oem 2” molded hose unit just won’t stretch that far, so I’m looking for a longer/taller one. Any sources? I tried Napa auto and found something close but no cigar. This one came off of a 454 MPI mag and worked fine with the flatter dual plane manifold.
Baja Rooster is offline
Old 10-03-2018 | 05:41 PM
Baja, I had the same problem with my Hardin Marine Intake. After exhausting all resources I found Hardin made a stainless barb/barb fitting and used 2 standard hoses. I used the upper from one and the bottom from the other cut to length where the clamps were in a convenient location. Ended up doing the same for the hose from the oil cooler to the t-stat housing. Here is a picture. Hope this helps.
GLENAMY 242SS is offline
Old 10-03-2018 | 08:28 PM
That doesn’t look so bad at all. What size coupler did you use? 2”?
Old 10-03-2018 | 09:01 PM
Hardin has the one for the recirculating pump hose, it is not in the catalogue so you need to call and ask it's stainless. The one from the oil cooler I picked up on line and it is brass that one is 1-1/4" I believe. The one from Hardin I am not sure of the size you will need to measure.
Old 10-04-2018 | 01:46 AM
Get a hose for a Merc 525SC. I believe they are a couple inches longer.
Hard to tell in the pic, so maybe have someone verify.
I believe Rambunctious posted that he is winterizing his 525SC's tomorrow, so maybe he could measure for you.
Griff is offline
Old 10-04-2018 | 07:06 AM
Knot 4 Me's Avatar
A 525SC hose worked perfect on a 7.4L where we replaced the standard cast iron truck manifold with a Edelbrock RPM Air Gap.
Knot 4 Me is offline
Old 10-04-2018 | 08:40 AM
Take your hose to your local hydraulic service shop and match up a replacement. They have all kinds of hoses and usually at a reasonable cost.
Here's one I found in the SF area.... https://www.pirtekusa.com/locations/pirtek-sfo/
Holy Smokes is offline
Old 10-04-2018 | 12:43 PM
I went to Home Depot and bought a threaded piece of galvanized pipe, painted outside black, two hose clamps and done.
1BIGJIM is offline
Old 10-04-2018 | 01:15 PM
Knot 4 Me's Avatar
Any piece of pipe/tubing will work as long as it is barbed or threaded/ Don't use anything smooth like PVC. That is what my buddy tried at first and ended up washing down his engine compartment a couple different times! That is when I hunted down the longer hose for him.
Old 10-04-2018 | 02:43 PM
Perfect. You and griff had the answer I was looking for. I figured some engine had to come from the factory with the taller intake I just didn’t know which one. I may use the Home Depot nipple trick to get me through the weekend.
