EFI to Carb Wiring
Old 11-17-2018 | 12:20 PM
Default EFI to Carb Wiring
Apologize if this topic has been beaten to death previously.
Getting ready to remove a 502mpi from the boat and replace with a carbed 555. Will any of the current wiring harness work ? Or will a separate harness be needed with the conversion from efi to carb ?
duplera is offline
Old 11-17-2018 | 12:56 PM
You’ll just have a bunch of wires and plugs left over. It works but just unsightly. I made a bracket to mount the gizmos to the back of the engine from port side header but had a lot of left over wire that needed shortened and at that point I wish that I just gotten a carb harness from CP.
https://www.cpperformance.com/p-1323...e-harness.aspx
All you need is the water temp, oil pressure, choke, and whatever else you want to add. The ignition wire wasn’t large enough to supply my DUI ignition so I ran that wire to a relay for a heavy
gauge wire.
Baja Rooster is offline
Old 11-17-2018 | 03:41 PM
Agree, can use it, and disconnect the EFI part from the engine harness, or get one of these and make a custom install, sell the harness you have on the swap shop maybe
https://www.michiganmotorz.com/custo...ss-p-4508.html
AllDodge is offline
Old 11-17-2018 | 11:11 PM
BUP
got some of the same and cheaper priced.
BUP is offline
Old 11-18-2018 | 10:37 AM
I was able to separate mine easily.
Hot Rod 29 is offline
Old 11-18-2018 | 10:50 AM
F-2 Speedy's Avatar
custom-mercruiser-style-engine-harness-p-4508.html
I've used these before, but their not complete you will need to reuse the large orange wire from the alternator to the starter battery feed, but their pretty well made.
F-2 Speedy is offline
Old 11-18-2018 | 11:49 AM
BUP
if stock engine set up and drive set up -- outdrive gear lube bottle alarm as well
BUP is offline
Old 11-18-2018 | 11:51 AM
BUP
correct about the alternator wire as its a bigger gauge wire as well.
BUP is offline
