Knock sensor needed?
Old 03-17-2019 | 11:08 AM
Default Knock sensor needed?
I going through both motors and when I had the blocks honed and hot tanked the one knock sensor was destroyed removing it. Are they even needed in the 500EFI motors. If so will a regular GM BBC one work instead of the Mercury Racing one.
s022mag is offline
Old 03-18-2019 | 07:12 PM
I would keep it. The 500EFI is a speed density system and has limited information to develop it's strategies, also removing it will most likely put it into "safe mode" and pull all of the timing out I don't know if they are standard GM knock sensors, but I would not be surprised if they are.
vee robb is offline
Old 03-18-2019 | 08:35 PM
Yes, you need it. It helps control the timing. I wouldn't try and skimp on this. The wrong one could trash an engine.
Griff is offline
Old 03-19-2019 | 10:53 AM
From what I’m seeing there around 150 from mercruiser. Is there any after market that will work just the same for less?
s022mag is offline
Old 03-19-2019 | 10:55 AM
F-2 Speedy's Avatar
I think I have a used 1 or 2 these are OE mercury
F-2 Speedy is offline
