-   -   Boat interior questions (https://www.offshoreonly.com/forums/do-yourself-boating-budget/360475-boat-interior-questions.html)
KeatonAZ 05-06-2019 01:36 PM
So I need to redo the interior in my boat for many reasons. a lot of the wood is rotting and falling apart, that is pretty easy to fix. I'm going to use the wood as a template some of the pieces i will use the foam as a guide because their is no wood left. router the edges to put a bull nose on, then paint with wood with some rustoleum enamel before covering.
Question comes down to a french edge vs a corded edge. other than looks is there any real benefit to a corded edge. Currently the interior is a corded edged but i have been leaning towards a french edge. seems the average house hold sewing machine can go through 3 layers of marine vinyl without issue, 4+ seems starts to have a problem and i would need to go to an industrial machine (vs the ~$50 craigslist/offerup )
corded edges are 4+
french edges are 2 + support fabric backer.
for reference
french edge/ stitch
https://cimg3.ibsrv.net/gimg/www.off...428a0708ae.jpg
corded edge
https://images.prod.meredith.com/pro...-9746pk1-3784c
Baja Rooster 05-06-2019 03:00 PM
I prefer the French edge anyways as it’s a lot more comfortable on bare skin and looks better.
Tractionless 05-11-2019 04:08 PM
If you fear it will rot again use structural PVC instead of wood.
KeatonAZ 05-12-2019 12:27 AM
Interesting you bring that up, I was talking about that. as well as using marine plywood vs pressure treated plywood that is coated in rustoleum enamel, logged in to ask that on here actually
Tractionless 05-12-2019 12:09 PM
My rear bench seat back and sides were rotted upon purchasing my boat and the upholstery shop I used recommended the PVC over wood. From what I'm reading lately about stringers and transom's using layered synthetics is a good choice as well.
KeatonAZ 05-13-2019 02:49 PM
Well I started cutting new wood this weekend. These pieces I could trace out.
https://cimg3.ibsrv.net/gimg/www.off...c3e39c5184.png
The old and new wood side by side. was a little hard to trace....
https://cimg5.ibsrv.net/gimg/www.off...3c4b4ec385.png
https://cimg7.ibsrv.net/gimg/www.off...09e67a9ad3.png
all the pieces are cut. (1/4 for sides & 1/2 for seats)
https://cimg0.ibsrv.net/gimg/www.off...946cce57cb.png
test fitting
https://cimg1.ibsrv.net/gimg/www.off...7b21078bbe.png
some overlapping i need to fix, it think. better too big vs too small. gonna trim off of the bow piece i think as it already has a slight F*ck up in it.
https://cimg2.ibsrv.net/gimg/www.off...e0faf5ef0c.png
both boards are the almost the exact same size (clamped them together and did the edges and turns) one covers the cup holders a little
https://cimg4.ibsrv.net/gimg/www.off...76006a8bd7.png
KeatonAZ 05-13-2019 10:31 PM
So I'm going to stick with the current color scheme of red/burgundy and an off white
what peoples thoughts on this material with a pattern. this would be on the edges of the pads and part of the bench seat where one would sit, everything else would bee an off white.
I think its kinda cool looking and not that expensive. Was thinking a textured material might hide flaws a little better since i'm amateur at this doing it DIY style (kinda like texture on drywall..)
https://cimg9.ibsrv.net/gimg/www.off...9a76a8f6f3.jpg
https://www.sailrite.com/Morbern-Hex...4-Vinyl-Fabric
1MOSES1 05-13-2019 11:13 PM
If you plan to keep the boat a while...I’d dump the wood for pvc or alternative plastic.
KeatonAZ 05-17-2019 01:06 PM
Bought a cheap machine off of offer up the other night for $60 then picked up some material to practice with. I tried the french stitching, seem the max length on the machine is closer together than I want.
https://cimg3.ibsrv.net/gimg/www.off...3e5e7054cd.png
practice and the machine jammed.
https://cimg6.ibsrv.net/gimg/www.off...1562d7af41.png
French stitch
https://cimg1.ibsrv.net/gimg/www.off...941885c89c.png
bobbin side, keep getting loose string and i dont know why, also not following my line and over shooting
https://cimg0.ibsrv.net/gimg/www.off...2e4eb18e7d.png
but it leads to a jam like this.
https://cimg5.ibsrv.net/gimg/www.off...828195b53d.png
noticed the thread keeps getting pinched between these pieces and it doesn't feed anymore then jams
https://cimg2.ibsrv.net/gimg/www.off...eba1d375dd.png
how it should look/feed
https://cimg4.ibsrv.net/gimg/www.off...359af07812.png
oconnor marine 05-17-2019 09:02 PM
Nice try.
The upholstery professionals hire me to fix their motor(im a marine repair shop)
I have them do the upholstery. I do the wood 1st.
i have a sewing machine and did some seats once a long time ago and they came out ok but definitely not something i would do on a nice boat. Its more frustrating than its worth saving the money. Save up and let the pro do it. Its something that will be a focal point. Best of luck
