First timer with marine headers... >
Old 08-15-2019, 12:37 PM
  #31
offthefront's Avatar
I've used the eddie marine with good results ....
https://www.eddiemarine.com/shop/exhaust-and-accessories/emi-thunder-exhaust-1/emi-thunder-exhaust-big-block-chevy-1/emi-thunder-exhaust-system-bb-chevy-with-high-perf-ss-risers-emi-511
offthefront is offline
Old 08-15-2019, 12:43 PM
  #32
Eddie Marine will also add O2 bungs for you.
Baja Rooster is offline
Old 08-15-2019, 01:10 PM
  #33
SB
Received 3,117 Likes on 1,403 Posts
Anybody make O2 Plates for Eddie Marine systems ?
SB is offline
Old 08-23-2019, 07:00 PM
  #34
No but they welded in bungs for me. I only wish I had read the AFR meter instruction page and had the bungs welded at a bit of an angle to reduce the possibility of the sensor getting water inside. The say to go more than 10 degrees above horizontal, but not straight down. Apparently straight down can burn up the sensor. Plates wouldn't be hard to fab up with the right gear. I think a welded bung would be tidier though. One less gasket, less height. Yada
NHGuy is offline
