Bbc 454 gen 4 overhaul
Old 11-08-2020 | 10:29 AM
  #51
Default Build
Ok so back to measurements for head gasket
It shows between 30k and 31k
Baja 250es is offline
Old 11-08-2020 | 10:36 AM
  #52
Default Build
This is what I'm installing
Old 11-08-2020 | 10:46 AM
  #53
did you rock the piston back and forth and take an average?
underpsi68 is offline
Old 11-08-2020 | 12:02 PM
  #54
Default Build
Yes 30 - 34
Old 11-08-2020 | 12:18 PM
  #55
mcollinstn's Avatar
Cut .034 off the block (zero deck). Then run .036-.039 gaskets.
Yes, it will increase compression, but the added turbulence from the "squish" benefits you MORE in both WIN/WIN categories. Power production AND detonation prevention.
Then, do some bowl work on the heads to unshroud the valves and add a few cc's to the chambers. Don't cut the heads unless they arent straight/flat.
I can't tell what carb that is.
Since you're running an aftermarket distributor, figure out your electronic advance and lock out the mechanical advance.
What ignition box/amp are you gonna run?
mcollinstn is offline
Old 11-08-2020 | 03:29 PM
  #56
Default Build
So I couldn't run a smaller gasket with the way the block is now and ignition is just factory setup still
Old 11-08-2020 | 03:56 PM
  #57
I can't speak for the ignition. But Cometic makes gaskets in about any thickness down to .027". They are the best on the market bar none. Using thinner gasket achieves same as cutting the block.
Smitty275 is offline
Old 11-08-2020 | 04:10 PM
  #58
Default Build
Thank u smitty that's what I thought but wasn't positive
Old 11-08-2020 | 04:50 PM
  #59
Only issue with the .027" gasket is your still going to be above recommended max "quench" distance of .045". Unless you're going for every last ounce of performance in a timed racing situation I doubt you'll ever be able to measure the difference it power.
Old 11-08-2020 | 05:01 PM
  #60
Default Build
I'm not at all I just want it to be right no issues all season
