Water Pressure Gauge quesiton
I would pull my volt/mph/hours gauges and put in temp/water-pressure/oil-pressure if I only had space for three.
perhaps you can find a dual input split gauge (one with two indicators on one face, or find a digital gauge that can be configured to have multiple displays like this and use some pressure senders instead of mechanical
https://www.ebay.com/i/293747613516?...4aAkVvEALw_wcB
My dash mount speedo always gave me problems, anything over 60 mph and the pitot would flip up. Found I was always looking at the chart plotter for GPS speed anyway. So I rerouted the speedo hose to the engine water jacket and now the speedo tells me block water pressure. But if I was going to add a gauge to the dash, I think exhaust manifold temp would be more useful.
So, I think I found the correct port on my thermostat...agreed? What size adapter should I use?
I have some Gaffrig water pressure gauges that came with these connection adapters...which are too small to go directly into the thermostat.
I did notice that my Hardin water pumps seem to have a unused port already (that looks like it fits one of the connectors/adapters I have):
That plug looks like it goes to the fluid reservoir for the fuel pump.
Use adapter bushings and take the pressure reading from the thermostat housing. That will give you the best indicator of pressure at the engine (will reveal blockages between the pump and block).
