motors running way too fat,
What is cid , compression, rest if cam soecs, and top rpm you are going to run with this engine ?
Are these carbs new ? If not , did they tun fine before fir you and then started acting crappy ?
Under load at a predetermined vacuum the power valve opens allowing more fuel to flow equating to 6-8 jet sizes. More load - less vacuum, 6.5 power valve will open at 6.5 psi manifold vaccum and so on.
Mark
12r-8795b
they are old carbs,,i am guessing from early 90's ,,when this boat was repower..
547's...10.3 to 1...fresh motors...plugs have always been too fat...
5600 is hardest i have pushed them....
thanks
with Holley, the casting numbers are raised (example is the pic supplied of the OP's 12R-8795B).. the model # should be stamped in somewhere on the body
What is the stamped # that is 180 degrees opposite your 12R # on top of the carb? ... that may be your model (list) #
i dont know if this helps,,,stamped on top side of carb....
