Gas gauge stopped working
Old 08-02-2021, 04:49 PM
Default Gas gauge stopped working
Hello,
I have a 2005 Sunsation with 496ho. Yesterday while driving the needle started bouncing between 3/4 and empty. I stopped and the level was at 1/4 so I added ten gallons which put the gas at 1/2. I checked the level last night after putting the boat away and now the gauge won’t turn on. Is there a way to check if it just the gauge?
waterman is offline
Old 08-02-2021, 04:56 PM
F-2 Speedy's Avatar
Received 3,075 Likes on 1,361 Posts
turn the key to on and ground the gauge at the sending unit and it should peg the gauge if its good
F-2 Speedy is offline
SB (08-02-2021)
Old 08-02-2021, 04:57 PM
SB
Received 3,131 Likes on 1,408 Posts
Back of gauge, Ground sender lug ‘S’ and if it pegs full , the gauge is good.
Take off big round plastic access cover on floor to gas tank fuel sender. If you connect ground stud to float level sender stud (middle of sender) and guage pegs full, the senders ground is good, wire to gauge is good, gauge is good, the sender in tank is bad.
SB is offline
Old 08-02-2021, 04:58 PM
SB
You sure are speedy.
SB is offline
Old 08-02-2021, 05:20 PM
Thank you both for replying.
I will check it next week.
waterman is offline
Old 08-02-2021, 07:44 PM
Received 1,826 Likes on 911 Posts
I'm betting you have a loose wire on the sender or gauge.
Griff is offline
Old 08-02-2021, 07:59 PM
Before I left I checked and the gauge and it was working so maybe it is a loose wire.
waterman is offline
Old 08-02-2021, 08:01 PM
SB
As an fyi: Fuel level senders are reohstats which can get bad spots. Ie: no reading / bad reading in spots of its travel.
SB is offline
liberator221 (08-02-2021)
Old 08-10-2021, 10:34 AM
SB
You fix it ?
SB is offline
Old 08-10-2021, 10:57 PM
I didn’t use the boat this weekend but I did put 25 gallons in it. The gas gauge was working but I don’t think it’s accurate
waterman is offline
