Originally Posted by SB
(Post 4815203)
You don’t need to if using stock merc tstat housing and circulating pump. It doesn’t close off anything per say, it just prioritizes (directs percentages) to block until tsat opens
Originally Posted by 1MOSES1
(Post 4815205)
since antifreeze is being heated and cycled…this will open t stat. Reason why it never opened on a hose is because it continuous cold water.
that’s not the case on a closed loop antifreeze tank. Yes Moses - my comment was more on the everyday flush when on the lift. Couldn't get stats to open obviously so went back to no thermostat. |
| All times are GMT -5. The time now is 02:36 PM. |
